- 2022/07/16
- 340
产品简述:
将其均匀地撒布初凝阶段的混凝土表面,经专门工艺加工,从而使其与混凝土地面形成一个整体。硬化地面具有硬度高,抗冲击,抗渗透的高致密性、色彩统一、耐磨性良好等性能。
Product Brief:
Nonmetal aggregate floor hardener is made of nonmetal aggregate, special cement and other addictives of a certain grain degree. It can be used as soon as unpack the hardener’s bag. Spread it on the concrete surface that is on the primary coagulation stage, then treat it in special techniques, so can make it with the concrete form a whole body. The hardened flooring has high rigidity, high impact resistance, high penetration resistance, unified color and excellent endurance, etc.
适用范围:
·工业厂房需要承受较大耐磨、耐冲击负荷或较频繁的作业区域
·要求洁净的生产区域
·适用于公共设施和商业用地,如购物中心、宾馆、学校、影剧院、医院、停车场、人行道、公路、庭院等
·适用于旧混凝土地面的改建工程
Application Scope
·The workshop that needs high endurance and shall be able to high load impact or frequently used working place in some industries.
·The producing area that shall be clear .
·The public facilities and commercial areas such as shopping centers, hotels, schools, theaters, hospitals, parking lots, pavements, walkways, gardens and so on.
·Reconstruction of old fashion concrete floor.
产品特性:
·增加地面的耐磨性和强度,提高表面密度,减少起尘防油性易清洁、抗渗透
·与混凝土地面一起施工,施工工期短
·耐久性好,减少了因周期性涂装或将表面增厚所带来的费用
·可配制各种色彩,达到美观要求
Product Features :
·It can enhance the endurance and strength of the floor, improve the density of the surface, improve the ability of dustproof and prevent oil stain and make the floor easy to clean and avoid water penetrated.
·For applied together with the concrete floor, it needs short construction time.
·High endurance reduces the cost resulting from the regular coating or thickened surface.
·Varies of colors are available, meeting the demand of beauty.
施工工艺 :
·在混凝土初凝时提浆、找平,第一次撒布耐磨材料及抹平、提浆
·垂直第一次撒料方向,第二次撒布耐磨材料及抹平、收光
·表面修饰及养护
Construction Techniques :
·Purifying slurry, leveling floor before the concrete sets. First spreading endurable materials and screeding, purifying slurry.
·Spead it on the floor against the line of the first time again and level the floor.
·Roll and coat the floor with transparent sealant
技术指标 Technical Index :
测试项目 Test Items |
指标Index |
耐磨性(齿轮法) |
Wear Resistance (Gear Method) |
≤0.03g/cm2 |
抗压强度(7d) |
Compressive Strength(7d) |
65.7Mpa |
抗压强度(28d) |
Compressive Strength(28d) |
77.0Mpa |
抗拉强度 |
Tensile Strength |
3.2Mpa |
莫氏硬度 |
Mohs Hardness |
8 |
冲击功(小颗粒) |
Ballistic Work (small grain) |
0.19J |
干缩值 |
Dry Shrinkage Value |
-0.751×10-3(210d) |
防滑性 |
Sliding Resistance |
同于一般水泥地面The same to the common cement floor |
防火性(按GB50209-95国家标准) |
Flame Resistance (Subject to National Standard GB50209-95) |
不发火地面Unfired Floor |
养护:
完成之后,对其的养护工作非常必要,这个时候可能就需要一些专业的技术去养护它了。很多人认为没有必要,其实这是非常错误的认识,耐磨地坪完成之后也是需要维护和保养的。
维护保养的时候应注意一下几个问题;
第一,本品不宜与含有氯化钙的混凝土合用;
第二,不使用于空气含量大于3%的混凝土表面;
第三,不能使用于含有盐或盐溶液的混凝土表面;
第四,产品中的水泥组分有刺激性,避免进入眼睛及长时间接触皮肤;
第五,耐磨地坪在使用过程中应避免硬物、重物撞击或冲击,避免锐器划伤和硬物颗粒附着地面,并保持地面清洁。如在使用中不慎损伤地面,
当耐磨地坪需要维护的时候,千万不要自己处理,当然如果自己有这方面的经验也可以,如果出现问题,最好找专门从事耐磨地坪保养工作的人进行维护操作。
